Hi, A few days ago i was on css, and my pc just started beeping, and the screen froze and i had to reboot. Then after that even when im doing nothing on the pc just on webpages its beeping and freezing for a split second, even when i boot up the pc it beeps, and takes its time rebooting. Then just before i was on the pc, on a webpage, and a blue screen appeared for a second cant remmember what it said, and then the pc restarted. But last night i was on Css for 2 hours streight and there was no beeping or restarts? hah: But even before this incident, my pc has been randomly restarting while playing games only, so i therefore put a house fan at the side of my pc case, with all the sides off, and this seemed to work. But now with this beeping even when i put the fan at the side its makeing no difference at all. Can anyone help. (Don't say try other Ram or another processor or another graphics card to see if thats the problem, because the Fact is i don't have any spare parts for my pc, and i don't wish to buy any parts for my pc to see if thats corects the problem, i have no money im skint.) Any help would be appresiated. also when its beeping i restart my pc and go into the BIOS to check temps and my CPU Temp was on 49c and my MB Temp was on 28c. Also i have downloaded this program called Motherboard monitor, and in the corner it says 35 37 27 My specs are. AMD 3200+ 1.5 Gig of them 512x3 Radeon 9800 Pro 128mb 120HD 400 Watt Power Supply.
wen i was on css, it was beeping, i went into the bios and it said CPU 51c or something and the MB was on 31c i think.
If you have overclocked your computer then bring it back to the normal position first. Tell us what type of beep your computer gives you when you start it? 2short 1long 1long or whateva...~!
I have not overclocked anything, i don't know how to. When it beeps its like a short Beep. then 5 seconds after another short beep. sometimes it beeps after another faster when it freezes. But at the mo it doesn't seem to be beeping. but about 5 mins ago b4 i restarted it was beeping all the time. it has been beeping all day its horrible. just beeped once more just then
Check [link=http://www.computerhope.com/beep.htm]This[/link] website and then tell me what kind of beep it is. However, also go to your event viewer and paste the last error you recieved when your computer hangs or whateva~!
Error Source = ntfs Catogory = Disk The File System structure on the Disk is curupt and unusuable. Please run the chkdsk utility on the volume C Another one Event Type: Error Event Source: atapi Event Category: None Event ID: 9 Date: 6/27/2006 Time: 9:17:41 PM User: N/A Computer: HOME-JDMW33LS4W Description: The device, \Device\Ide\IdePort0, did not respond within the timeout period. For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp. Data: 0000: 0f 00 50 00 01 00 a4 00 ..P...¤. 0008: 00 00 00 00 09 00 04 c0 .......À 0010: 00 01 00 00 00 00 00 00 ........ 0018: 00 00 00 00 00 00 00 00 ........ 0020: 00 00 00 00 00 00 00 00 ........ 0028: 00 00 00 00 00 00 00 00 ........ 0030: 00 00 00 00 07 00 00 00 ........ 0038: 40 00 00 0e 00 00 00 00 @....... 0040: 00 20 0a 12 40 03 20 40 . ..@. @ 0048: 00 00 00 00 0a 00 00 00 ........ 0050: 00 10 cd ba a0 f0 05 8a ..ͺ*ð. 0058: 00 00 00 00 70 fe 05 8a ....pþ. 0060: 00 00 00 00 0f b4 1f 02 .....´.. 0068: 28 00 02 1f b4 0f 00 00 (...´... 0070: 04 00 00 00 00 00 00 00 ........ Another one Event Type: Error Event Source: atapi Event Category: None Event ID: 9 Date: 6/27/2006 Time: 9:14:24 PM User: N/A Computer: HOME-JDMW33LS4W Description: The device, \Device\Ide\IdePort0, did not respond within the timeout period. For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp. Data: 0000: 0f 00 50 00 01 00 a4 00 ..P...¤. 0008: 00 00 00 00 09 00 04 c0 .......À 0010: 00 01 00 00 00 00 00 00 ........ 0018: 00 00 00 00 00 00 00 00 ........ 0020: 00 00 00 00 00 00 00 00 ........ 0028: 00 00 00 00 00 00 00 00 ........ 0030: 00 00 00 00 07 00 00 00 ........ 0038: 40 00 00 0e 00 00 00 00 @....... 0040: 00 20 0a 12 40 03 20 40 . ..@. @ 0048: 00 00 00 00 0a 00 00 00 ........ 0050: 00 20 0f b8 48 99 03 8a . .¸H. 0058: 00 00 00 00 18 97 03 8a ...... 0060: 00 00 00 00 71 ea 65 09 ....qêe. 0068: 28 00 09 65 ea 71 00 00 (..eêq.. 0070: 40 00 00 00 00 00 00 00 @....... Another one Event Type: Error Event Source: Application Hang Event Category: None Event ID: 1001 Date: 6/26/2006 Time: 8:40:27 PM User: N/A Computer: HOME-JDMW33LS4W Description: Fault bucket 126637809. For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp. Data: 0000: 42 75 63 6b 65 74 3a 20 Bucket: 0008: 31 32 36 36 33 37 38 30 12663780 0010: 39 0d 0a 9.. Another one Event Type: Error Event Source: Application Hang Event Category: (101) Event ID: 1002 Date: 6/26/2006 Time: 8:40:24 PM User: N/A Computer: HOME-JDMW33LS4W Description: Hanging application iexplore.exe, version 6.0.2900.2180, hang module hungapp, version 0.0.0.0, hang address 0x00000000. For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp. Data: 0000: 41 70 70 6c 69 63 61 74 Applicat 0008: 69 6f 6e 20 48 61 6e 67 ion Hang 0010: 20 20 69 65 78 70 6c 6f iexplo 0018: 72 65 2e 65 78 65 20 36 re.exe 6 0020: 2e 30 2e 32 39 30 30 2e .0.2900. 0028: 32 31 38 30 20 69 6e 20 2180 in 0030: 68 75 6e 67 61 70 70 20 hungapp 0038: 30 2e 30 2e 30 2e 30 20 0.0.0.0 0040: 61 74 20 6f 66 66 73 65 at offse 0048: 74 20 30 30 30 30 30 30 t 000000 0050: 30 30 00 This one was a Warning Event Type: Warning Event Source: Disk Event Category: None Event ID: 51 Date: 6/27/2006 Time: 9:17:41 PM User: N/A Computer: HOME-JDMW33LS4W Description: An error was detected on device \Device\Harddisk0\D during a paging operation. For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp. Data: 0000: 03 00 68 00 01 00 b6 00 ..h...¶. 0008: 00 00 00 00 33 00 04 80 ....3.. 0010: 2d 01 00 00 00 00 00 00 -....... 0018: 00 00 00 00 00 00 00 00 ........ 0020: 00 00 00 00 00 00 00 00 ........ 0028: 67 4a 00 00 00 00 00 00 gJ...... 0030: ff ff ff ff 03 00 00 00 ÿÿÿÿ.... 0038: 40 00 00 0e 00 00 00 00 @....... 0040: 00 20 0a 12 40 03 20 40 . ..@. @ 0048: 00 00 00 00 0a 00 00 00 ........ 0050: 00 00 00 00 a0 f0 05 8a ....*ð. 0058: 00 00 00 00 70 fe 05 8a ....pþ. 0060: 00 00 00 00 0f b4 1f 02 .....´.. 0068: 28 00 02 1f b4 0f 00 00 (...´... 0070: 04 00 00 00 00 00 00 00 ........ 0078: 00 00 00 00 00 00 00 00 ........ 0080: 00 00 00 00 00 00 00 00 ........ 0088: 00 00 00 00 00 00 00 00 ........ Theres loads il be here all day.
i think this has been solved so plz can u mark it as solved or if it hasnt, then i wud suggest a 'restore fail save settings' in bios or just reset ur bios. also rey to renistall windows with a full format
