fan control software for asus
Discussion in 'CPU, Motherboards and Memory' started by efx2003, Feb 15, 2005.
  1. efx2003
    efx2003 Big Geek
    fan controler software
    I have a Asus p4c800-deluxe motherboard and I was wondering if asus has a program that will control my fans. Or is there software that will work with my motherboard. I know that Asus has a program called Q-fan the will control my fans, but I am looking for a program that I can control the RPM's. Please help if you can. Thank You
  2. Big B
    I've heard [google]Speedfan[/google] might be able to do that for you, but I haven't used it personally.
  3. efx2003
    efx2003 Big Geek
    Thanks for the help. I will try it.
