Good morning all friends I am no longer a problem ... I have a PC, Motherboard Gigabyte P31 ES3G, Intel Core 2 Duo, 2GB RAM, Extreme 450Watt PSU, Seagate 500 GB SATA HDD (2 partitions 350 GB of data, 50 GB used OS win XP, 25 GB is still unallocated), WD SATA 160 HDD GB and LG DVD RW SATA, VGA Card ATI 512MB Radeon HD 3400 Series The problem, Seagate 500 GB HDD which is often not detected (sometimes detected sometimes not), whereas the WD 160 GB HDD and DVD RW LG no problem ... help me
Looks like you need to configure some options in BIOS. First off, to make things easier, make sure the drives are installed in SATA ports 0 and 1. Now, get into your BIOS. At the main menu, select "Integrated Peripherals". Set the "On-Chip Primary PCI IDE" to Enabled. Set the "On-Chip SATA Mode" to Auto. Save and exit. If the problem isn't resolved, try and set the "On-Chip SATA Mode" to Combined.
