Well, here is the deal, my power supply is overheating, yes I know, "Why don't you just buy a new one", I'm on a budget for a new build and I'm trying to see if I can restore this fan, back to working orders. The thing is when I boot up the computer I see the fan spinning but super slow, kinda like a laggy spinning fan, then it stop, and doesn't do it at all, I figured it was just dust on the fan or underneath the fan blades or hair for that matter. I need help with this any suggestions? Anything is helpful at this point. :dry:
You wrote that it could be dust or something like that , but you didn't wrote that you clean it up .. so , why don't you do that ? or just buy a new 12CM fan for you PSU !? replace it with the new one , and VUALA , it will work ! wish you good luck
