Ok so i've been getting advice from another forum but there is to many conflicting arguments so I'm going to see what happens here this is my computer: http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&dlc=en&docname=c03359045#N394 I'm trying to find the best possible upgrade to my GFX and PSU while not exceeding 500$ so far the choices I have been giving are GFX CARD http://www.newegg.com/Product/Product.aspx?Item=N82E16814150605 http://www.newegg.com/Product/Product.aspx?Item=N82E16814130782 PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139021 http://www.newegg.com/Product/Product.aspx?Item=N82E16817371016 The argument with the GFX card is whether my cpu can actually handle running it with "bottlenecking" the PSU argument is whether I need that expensive of a PSU I just want the best possible GFX for my computer without making it overheat or have compatability issues, Thank you for your help !
Mate Try this: SAPPHIRE HD 7870 GHZ EDITION OC 2GB GDDR5 CORSAIR Enthusiast Series TX750 V2 it wont bottleneck your cpu and its a great choice you decide - John
