Over Hit Problem
Discussion in 'Overclocking & Cooling' started by markjhun, Feb 12, 2016.
  1. markjhun
    markjhun Geek Trainee
    How do i know when my pc is going to over hit then suddenly it automatically shutting down...
    How I'm going to fix this problem..??
    Please guys Help....
  2. Big B
    Typically, the BIOS is set with a default shutdown temperature. Once that's been reached, the system is sent a shutdown signal in order to preserve the life of the system. Usually, this is related to the CPU temp and that will mean the CPU cooler is the subject of investigation. You'll want to make sure that the fan is spinning and if that works, blow out the dust.
    You can check the temperature in BIOS, but specifically where depends on the motherboard model. You can monitor the temps through Windows with programs like Core Temp which can read the temps straight from the CPU itself.
    That's what I'd check first.
  3. Ghostman 1
    I think you mean Over Heat ?
