i have a p.c problem,anytime i use my p.c,after 5 minutes it turns off just like that and my p.c fan doesn't roll/work, this are the things i think might have been the problem,i downloaded speed fan,did some temperature shuffling,i downloaded c.cleaner(a registry cleaner,it erased a part of my anti virus and now my anti virus is turned off,but basically what i am concerned about is my fan not turning ,how can i fix this,should i re-install xp,or what ,I'm confused.please my p.c is my life.how can i make my p.c fan work please i need help i tried system restore,but the system restore program did not come up,i use xp on hp,what could be the problem.
1. Try to keep a cool head, although it's not easy 2. can you rotate the fan with your hand (to see whether it's actually capable of rotating). If not - get a new fan, if yes - check the wiring to the motherboard - the connection might be loose. 3. Which fan of all possible case fans is that anyway ? 4. Some sad anti virus you got there if ccleaner recognized it as trash . I'd suggest you use Avira, Avast or AVG - all of them have freeware versions for home use. 5. Reinstalling windows should be a habit and done at least once a year. So, if you haven't reinstalled it lately, do that. 6. You can check the temps in BIOS. that's more reliable. 7. is your pc a desktop or a laptop? a whole load of unordered questions, but those need answers so we can see where we are.
That's true. Therefore we continue with the other thread: http://www.hardwareforums.com/p-c-problem-26778/
