Hi, Just got myself a 1700mm Plotter and its offline test seem to work but I cant get any response when i connect it. It connects via a serial port (9 pin). My computer has a Serial port listed as COM1. It also came with a serial to USB adapater and im having no luck with either. Help!! Cheers
Try the following steps: Make sure the plotter is turned on. Do a printer detection in Windows (control panels > Printers > Add new printer)
Hi, Yes probably should have said I have tried all that to no avail. And yes Plotter is on and plugged in etc Cheers
