The following is a very simple c++ program, that i believe should show the value of a variable x. since x = 1/3, i believe that the out put should be 0.3333, however, the output i get is x=0. can anybody tell me why? Code: #include <iostream> using namespace std; int main() { double x=10, dummy; x = (1/3); cout << "X : " << x << endl; cout << "Exit" << endl; cin >> dummy; return 0; }
If you do Code: x = 1/3; then it will interpret 1 and 3 as both integers, and put the result of the expression accordingly. To get it to display 0.333333 you need to change your code to Code: x = (1/3.0); or alternatively Code: x = (1.0/3); That way at least one of the values will be interpreted as floating point types, and so you'll get a floating point answer.
