im building my next computer using an sli board, and i was wondering if an sli board needs a certain type of psu for power requirements, i heard something about a 24 pin power connector needed. does any type of psu work? thx will this psu work ? http://www.newegg.com/app/ViewProductDesc.asp?description=17-153-015&depa=0
PowerSupplies can come in different forms: 24Pin & 4Pin 20Pin & 10Pin 20Pin Basically, 20Pin & 10Pin is used in servers, dual CPU machines mostly such as Blade servers, 20Pin was the power connection used on older motherboards upto AMD Athlon T-Birds, 24Pin & 4Pin are literally what ALL powersupplies use now for standard desktops / towers / file servers e.t.c (it's the most common). Yes the powersupply you listed would be fine - good choice as well.
