WOL after power failure
Discussion in 'Networking and Computer Security' started by ryvboy, Dec 23, 2010.
  1. ryvboy
    ryvboy Geek Trainee
    Hi all..
    When there's a power fail I can't start my pc in WOL but i've to start it manually..
    i read this
    what can i do?
    i discovered the wol connector on the mobo isn't connected with the network card.. could connect that solve the problem?
    is it a mobo or a network card problem?
    thanks
  2. SofiaBrown
    SofiaBrown Geek Trainee
    In the BIOS there should be a option on enable Wake On Lan (WOL). Once this is enabled, you can send a WOL "packet" to the network card using, for example, AMD Magic Packet, or other Magic Packet Utilites.
