Can someone tell me if connecting a 10/100 base TX jet direct box to a 10/100 Base T
or a 10 base T network will be ok or not and why ?
thanks
thanks
not sure about this, sine I’ve not had experience with setting up networks, I will see if I can some info on this!
I’ll have to look at one of my textbooks and see if they give something. I don’t recall there being enough of a difference to cause an incopatibility, but it’s not a bad idea to ask if you don’t know.
checks DataComm text
Okay, basically,
10Base-T is Ethernet
100Base-TX is Fast Ethernet
Fast Ethernet is simply a faster ethernet and is compatible. The signaling is the same, so it can be used.
