[FONT=arial][SIZE=3]I have a [SIZE=13px][FONT=Arial]Dell[/FONT][/SIZE] workstation 490 that has 2 duel core CPU’s on the mother board. The computer came with a 750W power supply (model N750P-00) that has two 24pin ATX cables required to run this computer. I’m upgrading the graphics card however and recently purchased a GeForce 670 FTW.[/SIZE][/FONT]
[SIZE=3][FONT=arial]This card requires 2 PCI-E power connectors (my stock PSU only supplies one) and I think it demands more power than my current PSU provides (current 18amps required 30amps minimum)[/FONT][/SIZE]
[SIZE=3][FONT=arial]I thought this would be a simple issue and went to Frys to buy a PSU with two 24 pin ATX connectors and the power I needed. They don’t have any. So I came home and started looking around online for a PSU that would work. I can’t find one. I called Dell, they don’t have one.[/FONT][/SIZE]
[FONT=arial][SIZE=3]so, what can I do? I’m running out of ideas. I was thinking about a small supplementary power supply like the boosterX5 but it is 450w and my GPU says it required a minimum of 500w. The booster might work still work however since it would not need to share power with the rest of the computer. I also need something that that will fit into one of my computer’s device bays because space is getting a bit tight. I don’t have much room in my case and adding a full secondary power supply is probably not possible. [/SIZE][/FONT]
[FONT=arial][SIZE=3]maybe a the most cost effective solution would simply be to purchase a regular power supply and use a cable like this:[/SIZE][/FONT]
[FONT=arial][SIZE=3][SIZE=13px][FONT=Arial]http://www.moddiy.com/products/Power-Supply-ATX-20%252dPin%7B4…QgodsC0AuA[/FONT][/SIZE][/SIZE][/FONT]
[SIZE=3][FONT=arial]to branch the power from the PSU to the two ATX connectors on the mother board? [/FONT][/SIZE]
[SIZE=3][FONT=arial]thanks in advance for your help and suggestions.[/FONT][/SIZE]
