40 vs 32 pin interface cable
Hi everyone. I am new to this forum. Glad I found you. :slight_smile:
Anyway, I have come across a problem that I am sure has happened before, yet I am unable to find a solution anywhere.
My internal factory harddrive has recently blown up and I bought a new one, a PATA /100 which I have just found out has different connectors than my previous drive.
My new drive requires a 40-pin interface cable, but there is only one slot on my board for such a cable. That one is occupied, and it should be. I do have other connectors on the board including a 32-pin.
Is there a 32-pin to 40-pin adapter I can purchase?
What is the solution here?
Thanks for your time.
Yeah i am also newbie to this forum and second thing i have not as much idea about hardware problems.but i can suggest you, if you thinking to buy any electronic components like data bus, connectors, computing cables, twinaxial cables like more with quality and quantity then visit milestek or milestek1553 sites. Hope that info will work for you
i think you are maybe confusing a 40 pin IDE connector with a 32 pin floppy disc connector
can you please attach a pic of your motherboard
SATA drives are pushing out PATA/IDE drives. Part of this movement involves reducing the number of IDE ports to 1 instead of the typical 2. I’m not aware of any 32-pin connectors, but as suggested above, you might be confused with the 34-pin floppy controller, which is entirely different from IDE.
While I don’t know for sure, I would guess that you have at least 2 SATA ports on your motherboard. If you want, you might see about returning that drive an picking up a SATA drive instead.
If not, IDE/PATA allows you to run 2 devices off the same channel, which while not ideal isn’t going to cost you anything to do. Of course, if you already have 2 devices on that channel, you’re out of luck.
The third option would be to purchase a PCI-based IDE controller card, like this one.
