5.1 surround probs
hey i bought the creative labs inspire P5800 works but the only problem is that i only get sound out of the 2 front speakers and the subwoofa i ran the test to make sure all the speakers were plugged in correct and they were. i was wonder if any body has got any ideas how i can get all 5 speaker working
Which file/program you are trying on your PC when the voice is not coming from your rear speakers?
In windows xp, go to CONTROL PANEL, and then SOUNDS AND AUDIO DEVICES. Right next to the speaker volume button, there’s also an ADVANCED button… select it. There you can select your speaker setup as 5.1 if it’s not already selected.
