Okay so they’re not calling it that but the Inquirer seems to think that’s what it is more or less.
http://www.theinquirer.net/?article=27400
Mighty tempting, for anyone with a ton of money to blow on a new top of the line card at least.
SWEET!
Damn that’s going to be amazing, imagine 4 in that 4 PCI-e motherboard you posted about a while back…
drool
heh
[COLOR=“Red”]EDIT: w00t 1600th post!
Well the 1800 XT wont be able to compet with that, it was basically a little better than a normal GTX, but with a core at 550mhz and 1800mhz memory, that thing is going to just brutally rape every game out there.
And considering current overclocked GTXs are pushing $500 and up, the ultra might be pushing $600.
Nice one Ex ![]()
I was going to post this info aswell, as a follow-up on my previous Thread!
Oh, sorry man, forgot about that thread for some reason. Yeah it will be pricey but remember the 7800 was supposed to be as high as $650 at launch and actully started at $600, then is down to $489 or so.
hopefully this will bring down the price of the 7800GT cause im thinking about buying one, soon.
My mouth is still hanging down in astonishment over the 1800MHz memory and 550MHz core, plus if it has a monster cooler there may be some overclocking potential, 2GHz memory maybe?!
I’m sure the cooler will be dual-slot massive and pretty loud but it will do it’s job. Don’t know if there’s much more OCing potential as with air cooling a 110nm process is going to get pretty hot and the memory is pretty much pushed to the limets but I’ll be you can still sqeeze a bit more anyway.
I can’t wait till this summer, because nVidia realesed its new line on the same date three years running, and hopefully they will make an 8 series with dual GPU ![]()
Yeah I won’t buy anything till dual core is cheap, the M2 socket is in, and 32 pipeline cards are common, next summer basically like you said.
