80mm Fan Roundup
AMDMB has a 12-way 80mm fan lovin’ going on for those who’d like to see how different fans stack up.
[size=1]A popular question in the Case & Cooling Forum here at AMDMB.com has been “Which fan should I use for my heatsink?†As more and more of these questions are posted in the forum, it has become apparent that a review like this one is absolutely necessary. For enthusiasts, picking a good heatsink and fan combination is just as critical as picking different computer parts. A good heatsink and fan combination means getting more MHz out of the CPU. With a wide selection of fans available in the market today, which fan is right for you?[/size]
I haven’t read it yet (typical me), but AMDMB has pretty good reviews, so I’d say this is a safe bet. I wouldn’t post stuff that’s crap…well, usually. :chk: Oh, yeah, a [u]link[/u] might be nice.
damn if I c the noice they make I’m sure if I buy my next pc im gonna use watercooler
I even think my volcano 9 at lowest speed(1500rpm) is loud lol but that can be due to my psu fan.
I saw watercooling for only 100 euro allready :smiley:
I guess it depends on what you can put up with. I have one buddy that put a ton of fans in his machine. It roared to life everytime you turned it on—literally.
As for watercooling, just make sure you get a mobo with the four holes around it.
I used to think that my system (with the stock hsf and one standard ballbearing fan) was loud.
After having listened to the vantec tornado, I now know what loud is !
Imagine having 4 in your case, thats what I had. It WAS CRAZY! And i MEAN CRAZY!
None the less, this review was awsome, althogugh ive used like 85% of the fans mentioned, im taking it cool, and i MIGHT buy a watercooling system, you need to have great knoledge, and know your stuff, if something goes wrong your SCREWED. AND you dont want to go cheap, cheap watercooling means cheap job wich means cheapp cheap which means it’ll fuxor up on you.
