8800GTX temps
Hi,
Does anyone know at what temp should a non overclocked 8800GTX work?
idle and underload temps please!
Thanks.
I don’t know if it’s the same as the 6 and 7 series GeForce, but if it is, the max is at 120*C. I wonder if Willz will answer…I’m pretty sure he has one.
I really hope so…
Like is 60°C idle reasonable?
For a video card, that doesn’t sound that bad. From what I’ve seen, video card tend to run much hotter than CPU’s do.
ok, then it should be fine… thanks!
60 degrees idle is perfectly ok. When I had an 8800GTS I had it overclocked to 620/980 and it idled at about 64, expect it to get into the 80’s at load, its fine :slight_smile:
ok thanks! :slight_smile:
