I have a BT Voyager USB ADSL Modem installed and it has two lights on it - PWR and LINK. The PWR light is always on. However, the LINK light starts flashing after the desktop has loaded some 30-60 seconds before. This means I have to wait a minute before I can use the internet at all.
Just wondering if there was a way to speed up the link process at all?
I dont think there is a way to speed up the connection! even so I dnt think it should take too long to connect though, it takes mine under 30 seconds, but I guess you could have alot of other things loading on startup?
do you keep the computer on 24/7? or have many users, if so you could do something so, every time you log off and on, you will still be connected to the internet!
