I’m wondering what to do for my next upgrade, I hear that this graphics i use is a weak one. Should i consider purchasing a new one, maybe a new processor as this is an old one. Or another GB of RAM.
I didn’t need any additonal cooling, in fact, my temps are the same (maybe like ± 1 or 2 deg). How so? Well, the 7600GS and the 7600GT both have identical GPUs only that they’re clocked differently (GS@400 and GT@560), so, theoretically, you should be able to run your GS almost (I’m saying almost cause the GS has DDR2 memory instead of the GTs DDR3) as a GT!
ATItool can be used for nvidia cards as well (I’m using it myself, as I stated in my first post).
I use all of them, but I would suppose that the 3d slider will adjust the clocks for the 3d mode eg the gaming mode.
the OC procedure:
increase the clocks for mem and core by, say 5 hz
test a few performance games (like oblivion or somethin else that needs a lot of power) for some time (say 10 mins).
did anything unusual happen (unusual things - artifacts, texture distortion, geometry crippling, crashes, freezes)?
YES - lower the clocks by 5 hz and test again
NO - goto step 1.
NOTE: you can also set your clocks as high as I have them (core@533 and mem@390) and see if your machine runs okay at that level and try and go higher following steps 1.-3.
