again 24 pin or 20pin psu??
I am not sure if its correct to post dis thread in this section or in the PSU section.. neways…:slight_smile:
i have a MSI mobo with 20 pin connector… i jus wanna knw if i can use my 24 pin PSU to power up the mobo by connecting only the 20 pins on the mobo and jus neglecting the remaining 4 pins?? bcos i found that there r some slight difference in the pin configuration between 20 pin PSU and 24 pin PSU…
Yes, you can use a 24 pin PSU with a 20 pin motherboard… most 24pin PSU’s come with the extra 4 pins as a block that you can slide off from the rest of the block.
thanks a lot… its working fine:)
good to hear :slight_smile:
have fun!
