AirStation On DSL NTL broadband
Ok this is how I’ve setup my wireless router…
Cable modem connected to PC via USB
Nfiniti Wireless router connected to pc via network cable
I’ve tried to install the Buffalo drivers it searches for the router but never finds it so I have to press cancel and exit the setup I installed the manager software and it says it’s not connected.
I mean I’ve like done everything to the book and I’m finding it some what stupid I remember why I never chose wireless its complete crap.
And when I try to enter the IP address to try and configure it never loads up the page, I’ve even installed a new network card into my machine to see if that’s the issue but to no luck the router just flashes at the network uplink so I know its connected.
Any Help will be apreciated thanks
Ok I fixed it it just sort of kicked in after an hour of playing and now it works with the original network card.
but also this particular model of wireless router has an issue I changed the root password and I know i don’t it correct and everything but it wont let me log into the IP configure system but it’s ok as the wireless works brill with my DS and my future Wii unit and my accesses point.
Sorry for the waist of space remove or close if you want thanks.
U can reset it to get it back to the original login/password and then do it again. But hey, when u say “AirStation”, u do mean either the Buffalo WHR-HP-G54 or the WHR-G54S? I’m not sure, maybe all the buffalo models say “airstation”? I know those 2 do. But if u got one of those, u should flash the firmware to DD-WRT! Or if urs is a different model u should check, it may be supported as well. But yeah all the reviews of those buffalo routers say that DD-WRT firmware is awesome. I have it and it seems really neat, although this is the first time I’ve ever even messed with firmware so I can’t compare. But if a n00b like me did it, u can too!
