ARRGGGG. help! pc not booting
I just tried to see if a network card was working properly by taking it out and putting it back in. Then i tried to boot it up but nothing comes up on the screen. I’ve tried moving some jumpers around to see if they do anything but nothing changes. My mobo is an ms-6378. An 800mhz duron, and a netgear network card. Does anyone know what the problem is? :confused:
I would check if all the cables are plugged in properly. You may have forgotten to put one back or took one out without knowing it.
Try some of these remedies
Usually if the video isnt coming on. Its a backwards ide cable in your cdrom or hard drive…losely seated video card..or two ide devices on the same cable are jumpered as the same thing ie. both are jumpered as primary or both secondary on the same cable..These are some of the more commom things…
Let me know how it works out…
its all right. i started playing with it and playing with it and playing with it and playing with it. Then it just worked. I still don’t know how i fixed it…
