Asus Eax1600pro
Hi i recently buyed this new Ati card and i would like to know if is a good medium card or if i just wasted my money thx
It’s a good mid-range videocard although it doesn’t perform a lot better than the same card with 256Mb memory.
For around 100 euro’s it’s a good deal, you didn’t waste your money.
Btw; Are you serious about those CPU temperatures? Those are way too high! You should invest some of the money you saved from buying that videocard into a better cooler, or else you won’t be playing games for much longer :frowning:
Good luck,
Marcus
Yeah those are my temps, i can’t manage to get the cooled i installed a chassis fan but the temp won’t go down maybe it’s a faulty temp sensor cause when i turn on the computer in the BIOS it says 88° Bah…
