Ati driver help
I tried to roll back my ati drivers, and even though it said it worked, the 7.9 are still there. I’ve never had this fail before, so I was wondering if i can simply install 7.7 drivers or do I need to uninstall, then install 7.7?
When I change drivers I do this:
Save new drivers on desktop.
Uninstall old drivers (which requires a restart.)
Once back up I use a reg cleaner.
Then install new drivers (which restarts again.)
Using this process I have never had any problems.
[COLOR=“DarkGreen”]You can’t directly install 7.7, if 7.9 is there. Only the upgrade is the possible. So uninstall the 7.9 driver first and install the 7.7 drivers.
