Avi Codec?
Hi guys. I’, having a problem watching a video on my PC. It is “avi”, and I’ve tried windwos Media, BS player, and such, but I can’t see the video, I only get its sound. Now, here’s the catch: I t created this video using FRAPS, from a wesite that only lets you stream their videos, but not save them to your HD. On the computer a created the video I can see it perfectly once I created it with fraps, but when I get home, I only get its sound. I figured it must be some codec that I’m missing on my PC. I’ve tried downloading several codec packs but still nothing.
Anyone has any ideas on what I can do to whatch the vid? It works perfectly on the original PC.
Thanks for your time guys.
Have you tried this one? It worked well for me a while ago when I had similar problems.
Download XP Codec Pack 2.0.6 - XP Codec Pack is one of the most complete codec pack
Also DivX
But I think this doesnt provide codecs for real and quicktime player files…:confused:
If they fail, then the K-Lite codec pack should do the job.
Ok guys, I’ll try those packs. Will see what comes up. I’ll keep you posted :cool: .
Hey guys, the problem is solved. Oddly enough, none of those codec packs helped the situation. I installed FRAPS on my home PC and voila, it worked!!! May be it’s some kind of special codec that fraps installs along with it?
Any ideas?
Thanks for your suggestions anyways :slight_smile:
