Im allso looking for an upgrade but am unable to go pci-e as my motherboard is old and only has agp !!! So what agp graphics cards would you suggest as the best in performance or the best in value ? Or should i think about a new motherboard instead ?
Thanks for the advice Big B , i thought i should have started a new one as i posted it , dohh ! ! Which motherboards would you rate at the moment as the best for performance vs value , expense always being the major hurdle ? Allso if an agp was on the cards as a QUICK solution for now are there any you WOULD recommend ?
