Best Card?
Ok, so what is the best performing card which also supports the latest games?
Give your choice for TOP PERFORMANCE and another for VALUE FOR MONEY
:rolleyes:
value imo, I would probably say the ati radeon 9600xt. My brother picked one up at newegg for $112USD. It was OEM, but still. 112 bucks! The speeds are 500mhz core/600mhz memory.
I may be wrong but I THINK the best performaning card is the geforce fx 6800 ultra. With 425mhz core and 1100mhz memory.
And dont think “oh hey, it has a faster core thats faster right?”
the 6800 ultra will have more pixel rendering pipelines, AND it has 256-bit memory… the 9600xt only has 128-bit.
Value wise, probably the Radeon 9800Pro, but that will likely change with the release of the GeForce 6600 and 6600GT.
The best you can get is the GeForce 6800 Ultra.
glad to see nvidia making a comeback.
A pretty good value for a high-end card is the 16-pixel-pipe version of the NV 6800. They’re just under $300, and you should see the framerates. :smiley:
time sure does fly. only 9 months ago the radeon 9600pro was the king of value cards. why back then i used a crappy nVidia Vanta16.
The best money can buy would be the GeForce 6800 Ultra Extreme Edition which costs about 600 bucks last time I checked it out. My 6800GT OC from BFG only set me back 430 bucks(with tax) and I easily over clocked it to 445/1200 but run it everyday at 430/1200.
But, with the X800 XT PE only a few frames per second behind, at times ahead, its also a kick-ass card so its really a brand preference. Unless you want the support of SM 3.0, then go with nvidia.
As for a value card, 9800Pro 128mb no doubt.
