If you havn’t purchased the cpu yet then I’d buy a socket 939 mobo and cpu to go with it. I’d go with a a mobo by MSI or Asus, but I’ve heard bad rumours about some Epox mobos.
the main prob is the money, i have to keep it under 2000 AUS and thats including monitor, how can i link u to that website if i cant use normal linkage?
its www.gamedude.com.au … heeeeelp
i cant go to the 939 chips cause they are so friggen expensive and there are only like 3 mobos avaliable from this site ..
would i be better off going with the Socket A chips? of maybe intel?
im confused.. im good at shopping for everything else but mobo’s
By default, you can type the full address in and the forum software will automatically enable it. The link above is a list of the vB codes you can use. Pretty similar to HTML tags, but they use instead of < >
[QUOTE=harrack52]
If it absolutely has to be a motherboard from that list, I’d take the MSI K8T Neo.
However, I suggest you go with the MSI K8N Neo, which is basically the same board with an nvidia chipset, instead of via.
I admit there is a significant price difference.
Is there much of a performance difference between the via and nvidia nforce chipsets anyway? With new tech i wouldn’t imagiine a noticable difference.
