Bizarre horizontal lines problem
Hi all. Hope you’ll be able to shed some light on a freaky problem I’m having.
At random occassions I’m getting flickering horizontal lines across my screen, mainly concentrated at the top half. I immediately thought it was a hardware fault but after noticing a few things I’m starting to doubt it. Here are my observations:-
  1. The lines are only noticable when having a mazimized web broswer window on my desktop containing images. If it’s text only there are no lines.
  2. If I have a non-maximized window I get no lines, but if I drag the window onto an area of the Desktop where there are icons in the background, the lines immediately reappear. They also disappear as soon as I drag the window away from the icons.
  3. If I temporarily change resolution and then change it back, it -usually- gets rid of the lines.
  4. If I use the ‘Orientation’ option in the Screen Resolution (Control Panel>Appearance and Personalization>Display) and change it to ‘Flipped’, then revert straight away to normal, the lines disappear.
  5. When the lines are present - it’s totally random, regardless of GPU load or uptime. I’ve had it as soon as I opened my browser from a cold boot, and after a few hours of gaming - leading me to believe it’s not a hardware issue such as heating. I’m also getting no other performance-related problem which would indicate any hardware problem.
I’m running Windows 7 64-bit with the latest WHQL 191.07 drivers on a GTX295. I’ve tried older and beta drivers but the lines keep appearing.
Anyone else experience anything similar?
I had quite the same problem with my monitor.
You should try change the power supply cable before anything.
It looks like this → http://www.reciclaprint.com.br/home/components/com_virtuemart/shop_image/product/Cabo_de_For__a_48626f92a18a9.gif
