Can anyone please help? I get constant problems with computers, (maybe its just me). Anyway, my custom built pc recently started to act strangely. Sometimes when in normal use, the screen goes blank; fans slow down; hard cd drive makes strange noises. This usually happens then when i try to restart, the computer does even start up, just does it again. Because this happens almost instantly when i turn it on, i don’t think its the RAM, drives or graphics card. I suspect its my motherboard that causing this. Any help will be appreciated.
Spec:
MSI K7N2 delta-L
Athlon 2700 T/Bred B
GeForceFX 5900
Seagate barracuda 7200.7
LG GCE something something
One beep signifies that it’s good. MSI uses either an Award Phoenix or AMI BIOS.
RAM is a possibility, as I did have that board awhile back and it was picky as hell over the RAM…and I eventually returned it because of that. However, I had trouble getting it to even boot from the get go.
if you can try testing another PSU in your machine thats ahving problems (one that you know works fine) if all is still the same its most likely your motherboard..
and if u cant be bothered to test your ram or MB by deduction.. get a rubber and a soft lead pencil run the soft lead pencil over your motherboard hard.. then get rid of the marks using the rubber (causing static) also, get the rubber and rub it over your ram very fast causing lots of static.. therefore this will definately stuff your ram and motherboard then send em back (although do this once u’ve removed it from case and they have no connections to any electricity or any working components)*
*of course only do this if they are still under warranty because u’ll get a full replacement for both parts (or should do)
also.. this is just an “idea” nothing that i have ever done myself
Thanks but i think its my processor. I’ll try to swap some components. PC World said they chardge £50 for the first hour and £25 every one after that for repairs. I don’t think thats including the cost of new components if needed!
if your computer is past its warranty go and take it to a small computer shop, u’ll get it cheaper, cost you around £30 for the work, (as long as u tell them its the processor)
also.. if you brought your computer from PC World.. you really should be shot.
