Build flash websites in linux
I used to have a simple program for windows which allowed you to easily throw together flash websites using templates.
Does anyone know if there is something similar I can use in linux?
Ive obviously done some googles but I seem to have lost the knack of good google searches recently!
You could try running the Windows Flash program under Wine. Configuring Wine is not that difficult if you use Wine-Doors
Ive just installed wine hoping this will work.
Many Thanks
if your messing with Wine, you could take a look @ The Wine Bible
