Here it is…
Case- $130—Thermaltake Xaser III V1000A Black Chassis: 1.0mm SECC Japan Steel; Front Panel: Aluminum ATX Mid Tower
http://www.newegg.com/Product/Product.asp?Item=N82E16811133105
Power supply- $75—Antec TRUE430 ATX 430W Power Supply
http://www.newegg.com/Product/Product.asp?Item=N82E16817103908
Mother Boards- $110—ABIT AV8 Socket 939 VIA K8T800 Pro ATX AMD http://www.newegg.com/Product/Product.asp?Item=N82E16813127181
OR
$114----ASUS A8V DELUXE Socket 939 VIA K8T800 Pro ATX AMD Motherboard
http://www.newegg.com/Product/Product.asp?Item=N82E16813131510
Processors- $275----AMD Athlon 64 3500+ Venice Integrated into Chip FSB Socket 939 Processor Model ADA3500DAA4BP - http://www.newegg.com/Product/Product.asp?Item=N82E16819103532
Or if there isnt much of a difference…
$159----AMD Athlon 64 3000+ Venice Integrated into Chip FSB Socket 939 Processor Model ADA3000DAA4BP -
Video Card- Now i already have a 9800pro. Some think the 6600 GT is a minor updrade so no need to updrade here orrrr maybe…
$383–ATI All-In-Wonder X800 XT 100-714200 All-In-Wonder Radeon X800XT 256MB GDDR3 AGP 4X/8X http://www.newegg.com/Product/Product.asp?Item=N82E16814102492
Memory:
–I am not too sure out of these three, the last two might be the same, and all are x2 = 1GB–
$85—crucial 512MB 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered System Memory Model BL6464Z402 - Retail
$107—crucial Ballistix 512MB 184-Pin DDR SDRAM DDR 500 (PC 4000) Unbuffered System Memory Model BL6464Z505 -
$135—crucial Ballistix 512MB 184-Pin DDR SDRAM DDR 500 (PC 4000) Unbuffered System Memory Model BL6464L505 -
Hard drive—$107—Seagate Barracuda 7200.7 ST3200822A 200GB 7200 RPM IDE Ultra ATA100 Hard Drive -
CD/dvd roms— any suggestions?
Total=
$1,295 with the ATI x800xt vid card
or
$912 with my 9800pro vid card
Things i already have on my current system that will be used on my new rig:
Sound card:
—CREATIVE Sound Blaster Live! 24bit 70SB041000000 8 (7.1) Channels 24-bit 96KHz PCI Interfacesound card
Speakers:
—Logitech X-530 70 Watts 5.1
Frequency Response: 40Hz - 20kHz
Signal to Noise Ratio(SNR): >96dB
Monitor:
ViewSonic VX910 19" LCD Monitor
19", 1280x1024, DVI, PC/Mac - SKU: VX910
Any comments and recommendations are greatly appreciated!! thanks! ![]()
