C++ Builder and USB<->RS232
[INDENT]I am trying to make an application with C++Builder which communicates with a PIC16F877A which has a RS232 interface. Unfortunately my computer only has USB ports so I have bought a USB to RS232 converter cable.
Well I am a complete beginner to C++ Builder so really at this point I don’t even know it will be possible to do this… Any help and advice would be really appreciated.[/INDENT]
Well if there are primitives and/or libraries for sending commands to a LPT prot, then you should be fine. Blunt data sending should be enough. Try to do copy a plaintext file directly to the LPT port (usb prot) via Command line and see what happens. In worst case you should be able to create a bat file that you run from your C++ app.
