C840 Wireless
Ive got a Dell Lattitude C840 laptop and for some reason the wireless connection won’t work. It see’s networks fine and connects to them with its internal card and a PCMCIA one i tried, but the problem is it cant get an address from the DHCP. It goes through the motions but cant pick anything up and gives in. I used static IP adressing with the same DNS and Gateways as the machines on the network and it doesnt see anything on the network or get the internet? However it works via ethernet cable and gets an address. Any Ideas?
Ive already tried:
Uninstalling and re-installing the TCP/IP protocols
Uninstalling and re-installing the Wireless devices
Restarting the DHCP client
Hi,
You may want to try the steps in this article to troubleshoot, specifically the steps for Drivers that do not support the Wireless Zero Configuration service. How to troubleshoot wireless network connections in Windows XP It has some good steps to check to make sure your wireless device is configured. :slight_smile:
Tried changing the frequency channel yet?
