CD Drive Tray
Dear Friends,
Whenever I am trying to open the CD tray it just opens and closes immediately automatically. How to solve this problem?
Sweetie
[QUOTE=sweetie]
Hi Sweetie welcome to HWF, shut down your system and insert an unfolded paperclip into the tiny hole in the front of the CD drive[ot]you will feel some reistance after you have inserted it a couple of centimeters - which it normal, keep pushing the paperclip until the CD tray ejects manually and pull the tray out a bit more, then turn your system on (with the tray ejected)[/ot]when your system has booted - press the eject button a few times - all should be ok now
