CD-rom drive and mini cd`s ?
hi folks, i bought an mp3 player which is xp compatible. The software came on a mini cd ! I was assured you just put it in the drive and would read as normal but it doesnt. anyone help?
You should be just fine, make sure the mini cd is in the middle of the cd tray
no, tried that
well, there’s no reason that it shouldn’t work unless something is wrong with the drive. Can you try it in a different system and see if the minicd even runs?
