cd-rom problems
I have a sony CRX320E cd-rom drive and ever since i formatted my hard-drive, every time i write an audio cd, all the tracks are jumpy. I suppose it is a driver problem but i cannot find any drivers for it. Could anyone help or suggest any other advice? thanks
  1. Try burning at a slower speed
  2. I’ve had this problem before, and the only way that I can seem to get around it is to use a different burning app. I used Nero, and it was giving me choppy audio, but since I’ve switched to NTI CD/DVD Maker, it works fine, you might want to check it out.
[QUOTE=StimpE]
i have tried writing at 1% (takes forever) but it was still really ‘choppy’
I will see if i can get an NTI demo and get back to you. Thanks
I have downloaded the 30 day trial of NTI and it works ace. Thanks for the help!
[QUOTE=sutton]
Anytime man :slight_smile:
