+ CFP MSA compatible PHY with MDIO
Hi, we are looking for best solution to configure CFP MSA compatible PHY with MDIO interface. The best would be to have some USB to MDIO adapter with LabView support.
Try SUB-20 SUB-20 Multi Interface USB Adapter USB to I2C SPI GPIO RS232 RS485 Ir
It has 2 MDIO channels. One is CFP compatible running at 1.2V with 4MHz MDC frequency.
SUB-20 has integration modules for LabView. Low price, good support, reliability. What else?
We use SUB-20 as I2C master as well and also via LabView module.
