A week ago, I replaced my rig’s PSU with new one as the previous one blown out, the new one is ThermalTake TR2 430W, while the old one was Huntkey 600W.
Installed it, and noticed that at higher CPU usage the display starts to shake or flicker, as if there’s lack of current.
Tried to do a trick, changed the LCD monitor refresh rate from 60hz to 75hz and somehow that visual effect reduced much. But I’m afraid the higher refresh rate will effect badly on my monitor.
So is it the PSU issue? I heard a suggestion from another forum: if the PSU wattage is low it can power up the PC or never able to boot at all.
The system is:
GA-Z87X,D3H
i7 4770k OC to 4.3 Ghz
Ram: 1333, 16GB (2*8gb)
HDD: Seagate 2TB @7200 rpm 64mb cache
Video card: PNY - nVidia Geforce GT 640 (no dedicated power plug)
PSU: ThermalTake TR2 430W
Looking forward to hear from you guys. Thanks a lot & have a great day.
Sincerely
Saif
Usually bad PSU’s damage motherboard first, so processor may be intact.
There is some risk but then that’s good way to sell “cheaper” monitors (just limit refresh rate a little on “cheaper” model).
And this all happened after PSU exploded? Then PSU explosion may have something to do with it.
I would first try with different video card also. That issue (CPU usage goes up and problem starts) sounds very bad and mosty probably that won’t help. It’s also possible that new PSU is faulty. Some parts are just DOA. 430W for that rig is more than enough though.
