cheats for gta sa (pc)
da real easy n FUN way to get 6 star is to KILL anything..anyone even the cops/ old honnies in the streets…ha..tat isnt a cheat and way more fun!!!
I guess you have to be well into the game on other islands as it won’t let me go past 4 stars no matter how many police helicopters I blow up.
[QUOTE=pelvis_3]
trainers just run in the background along with the game, eg- you start the game>minimise>start the trainer>then maximise the game and then all the cheats work automatically!
Not exactly. Basically a trainer gives you a list of codes that can be enabled, usually ones that aren’t included in the normal cheat codes or in games that have no cheats (strategy games, mainly). You run the trainer in the background and use hotkeys while in-game to give the desired effect according to what game and what trainer. A word of caution though, trainers can be highly unstable and mess with your game settings, use them at your own risk.
And Ex, yes, you do have to get further into the game before you can increase your wanted level beyond 4 stars.
I wouldn’t use them unless I was totally stuck, even then I’d probably just get my friend to help me out or something. My computer’s screwed up enough as it is. Thanks for the info WWR:)
