Cobind problems
I go to put linux on my laptop. I put my cd in the drive and it boots from disc and tell me do i want graphical or text (I have tried both) Then it comes up loading kernal. The starting anaconder - Cobinds installer
then says installer has shut down due to abnormal exit.
Does this evry time WTF shud i do :confused:?
have you got the problem sorted or just leaving it?
maybe the graphics card in your laptop work in linux?
No I didnt find out the solution i just used another linux distro
I know you’ve gone on to another distro, but I thought I’d point out for posterity that the problem was probably that your burned CD image was corrupted.
Yeh but a had six cds of cobind and every one did the same :frowning: maybe it was my cd drive
Try floppix or DSL :wink:
I did already
