Hi im just wondering if its possible to connect a VCR/DVD combo to my computer? if so would it be expensive
yes it is possible, why, what do you want to do it ?
[ul][]to watch DVD’s / video’s on PC[]movie output on you TV from files that originate on your PC[/ul]or do you want to do something else ?
I want to use my m0onitor sort of like a tv , just for viewing
so you want to take the output from the DVD / Video and have it displayed on your moniter, yes ?
if that is the case, it depend on your DVD, Video, grafx card and sound card
but the easiest way to do it is: just throw a TV card at your system, like one of these[ot]just don’t throw it too hard, cos you may break something[/ot]
i want to buy graphic card for AGP slat with 256 MB memory and i want to captur with it
for example connecting vcr to computer and changing video tape to vcd
what card is suitable for me?
If you post inside of another thread then I doubt that u will get replies easily. It would be great if you start a new thread for this. Also let us know wats ur budget?? coz that makes big difference…
