Constant Crash with Medieval 2 Total War
I get to specific point during the game and it crashes 100% of the time.
It happens when I try to display a massive amount of units on the screen at once, (though during a different point in the game I was able to view over 1000 at a time…didn’t crash just incredible slow down.)
Throws me this error message:
The Instruction at “0x135a64a8” referenced memory at “0xec5d015a”. The memory could not be “written”.
I’m running the game on the following specs
AMD 3200+ (Venice)
1GB DDR 400 RAM
Nvidia 6800GT 256MB PCI
at this point I’m thinking that my RAM is bad…but everything works fine so long as I don’t play the game upto that point. I turn all of the settings down to their lowest and it still crashes. Any help would be awesome.
PSU make and wattage?
Slowdown and crashing with mulitple units on screen can be one of many. i experienced the same kinda probs with B & W 2. I put it down to my graphics card not getting enough power.
JPAC 550ATX ATX 550Watts Power Supply 115/230 V UL, CB, CE, TUV, FCC
Model
Brand JPAC
Model 550ATX
SPEC
Type ATX
Maximum Power 550Watts
Fans 2
Main Connector 20 + 4Pin
Dual +12V No
PCI-E Connectors No
SLI Support No
Modular Cabling Support No
Over Voltage Protection Yes
Input Voltage 115/230 V
Input Frequency Range 50/60 Hz
Input Current 10A @ 115V, 5A @ 230V
Output +3.3@30A,+5V@50A,+12@20A,-12V@1A,[email protected],
Not sure what you needed so I just copied everything from the invoice…hope this helps
Run Memtest86+ - Advanced Memory Diagnostic Tool to check the RAM errors~!
In this months PC Gamer (UK) there is a small section saying that this has been happening to a lot of people and that there is a patch out with bug fixes, it doesn’t say where the patch(es?) can be found though!
