Content Management System
Hi!
Could you guys give some opinions on which is the best CMS (using PHP preferably) out there? :confused:
thanks!
There’s a list of CMS on wikipedia
(at the bottom of the page)
PHPFusion seemed good, mambo/joomla! might seem a bit overkill.
thanks for the suggestions!
@Addis: I was thinking in the joomla/mambo way a bit. Why do you say ā€œoverkillā€. Are they big, complicated… ?
When I’ve tried them, yes. PHPFusion seemed to have the right balance, and I’m sure you can customise it. However, I know a site which uses Joomla quite well, Manchester Linux User Group - Home
Of course you can try it, and see what you think. You may find some of the features useful :).
I’ll certainly try them out, Addis.
But for now I can give some credit to Websitebaker. Nice. Nothing more and nothing less. Really fast and easy installation. Some bugs there, but nothing crutial. Also, several language packs are available as well.
