I’ll update this thread as an when everything is here e.t.c
But sometime this week i have arriving:
Akasa AK-PAX-2 PaxMate Plus Acoustic Absorption Mat (Deadens Vibration & Noise of case / fans / hdds)
Arctic Cooling Freezer 64 CPU Cooler
2 x 80mm Silent Vantec Case Fans - 20DB @ 2100-2200RPM
Then sometime in the next 2 weeks i have arriving 512MB-1GB of PC4400 OCZ GE, depending on when i order it
Hopefully i’ll be reaching my ultimate dream - a good nights sleep with my pc being left on!
My PC isn’t loud, it’s just the frequency it makes is irritating and not a soothing noise
Boland on a different note, how are you running an Athlon 3200+ with PC2100 memory? the 3200+ requires an FSB of 200Mhz, and PC2100 only provides 133Mhz.
My rigs aren’t all that loud…now that rackmout switch is a bit noisy. It doesn’t bother me all that much really. If I’m tired, I will go to sleep (even when my little bro has band practince outside my room).
[QUOTE=ProcalX]
Well literally the only thing making noise in my computer now is my graphics card, everything else is literally inaudiable :good:
I can highly recommend the Artic Cooler Freezer 64, stock my temps are:
CPU:29-31C (idle) 36C Load
SYS:22-25C
PWM:26-29C
Going to stress it out with some F@H and see what the temps look like
OK, with my computer OC’d to 2.3Ghz from 2.0Ghz:
FSB 230 x 10 / LDTx4 / DDR VDimm: 2.7V temps are:
CPU:33C (idle) 41C Load
SYS:25C
PWM:34C
And thats after running F@H for an hour
Sounds like you got a happy little system thar. Right now I have 10 fans in my case. 4 of which are vantec stealths producing almost no noice, but my case does VERY good dampening fan noise and vibrations
