Cpu fan for 2.8ghz fsb800 intel question
I have a Intel 2.8GHZ FSB 800 and a heat sink Thermalright sp94. Can sombody tell me what would be a good fan for this. I am looking for a fan that is not so loud but gives good air flow. CPU is not overclocked and I do not play games on it. I was thinking on getting a Panasonic Panaflo FBA09A12H -1BX 92mm Hydro Wave. Please help if you can.
Thank You
id say you will ok if you use a 92mm fan as they are quiter than 80mm fans, get one with a 3pin fan connector and also consider pairing it with say a zalman fanmate 2 or something!
What would be a good CFM for the CPU. Please reply
might i add you could consider getting a aluminium fan as they are even quieter than plastic fans but oviously heavier!
a good airflow rate would be anywhere from 45-50CFM !
Thanks for advice.
