cpu fan question
I am looking on buying a new cpu fan. What is a good “cfm” for a cpu fan. Please help if you can. Thank You
well coolmasters a good make along with other like thermaltake if your looking low budget q-tec is a good cheap make. what processor and socket are you cooling?? and in addition to a fan thermal compound is needed i reccomend coolmaster artic silver over the standard cooling past that comes with a retail fan. hope this helps Dave :good:
I have a 2.8c HT and 875p chipset. I am looking for something is quiet and has plenty of cfm. I do not mind paying for something good.
Please reply.
Thank You
socket?
478 socket. please reply
http://www.newegg.com/app/ViewProductDesc.asp?description=35-106-032&depa=1
look at that!
http://www.newegg.com/app/ViewProductDesc.asp?description=35-106-606&depa=1
or that, only $ 10
Thanks for the advice.
no prob
