cpu temperature
Is 34 degrees c hot or cool for cpu temp?
What CPU are you talking about?
And is that 34*C when idling or under load?
Either way it seems fine.
That’s a good temp. Anything under 60C is fine, but if you’re hitting 50C under load, let alone idle, then you might consider a cooling upgrade…after making sure the cooler is making proper contact.
