well i had my 2400+ oced to 2.4ghz and then i put i back down to 2000mhz but its running way to hot when i first got it it was running at 45 degrees but now its at 65 degrees and i have 8 case fans and the stock cooling is still on the cpu any ideas
I would reseat the the hsf on the cpu.
Also, you could clean it, especially if you’ve never done it.
If all of the above fail, then look into buying another hsf.
yeh thanks also my mother bourd is continuously beeping at me since then as well
It’s likely saying the CPU is getting too hot.
yeh i relise that thank you does any one know wat Vcc1.5 cos i keep egting errors saying that the Vcc1.5 voltage is to low or to high
That’s your CPU core voltage. The default should be 1.75V.
I believe the default voltage for that cpu is 1.6V
